1999 Chevy Corvette Cruse Controll
JIM ZITTLOW
Engine Mechanical problem
1999 Chevy Corvette V8 Two Wheel Drive Automatic
My cruse controll come off when I hit a bump in the road. I also need to lift the brake peddle before I can set the curse. The sensor needs to be adjusted.
Is it located on the brake peddle like in older cars?
I tried to look, but the space is so small and covered with a panel that I can not see anything.
Could it be located under the hood.
I would like to make the adjustment myself if possible.
Thanks
Jim Zittlow
Sep 23, 2008 at 12:10 AM
  • 75,988 POSTS
The brake switch is at the brake support bracket-if you follow the brake pedal arm it will lead you right into it. Its gonna be hard just be patient.
Sep 24, 2008 at 10:34 PM
