1998 Chevy Corvette Wont Start
97,000 MILES • V8 • 2WD • AUTOMATIC
PRIMETIME98
I was driving my car and it died. I went to start it and it wouldnt kick over, it sounded like it wanted to start but it didnt. It makes a noise when I try to start it but it wont turn on. All electrical works. I was hoping you can tell me what the problem is thank you.
Sep 13, 2009 at 6:50 AM
  • 75,988 POSTS
Do below to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sep 13, 2009 at 9:03 AM
