1998 Chevy Corvette end link replacement
132,000 MILES • V8 • 2WD • AUTOMATIC
GWPICKETTE
To replace the end links on a 1998 corvette, do you take off or loosen the sway bar brackects or cna they be done with doing the above?
Oct 28, 2009 at 9:02 AM
DOCFIXIT
  • 18,828 POSTS
The sway bar links can be changed without sway bar removal. When tightening do so till rubber is slightly squeezed bigger then washers
Oct 31, 2009 at 7:41 AM
