1998 Chevy Corvette Cruise Control Problem
52,000 MILES • V8 • 2WD • MANUAL
F43906
Originally, the fuse for the cruise control would blow and the check engine light would turn on. Currently, the cruise control will not function, the fuse does not blow but the check engine light now turnes on. What could be the problem? P.S. The check engine light that is "on" does not affect the drivability of the vehicle.
Mar 24, 2009 at 6:49 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your engine size in liter and the 8th digit of your VIN.
Next, please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
Mar 24, 2009 at 9:06 AM
IMPALASS
  • 3,112 POSTS
Hello - By the way, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Recalls_17.jpg
Mar 24, 2009 at 2:29 PM
