1996 Chevy Corvette third brake light
30,000 MILES • V8 • 2WD • AUTOMATIC
CORVETTE96
I want to install a new third brake LED light kit..How do I get to it to remove and change it out...At the license plate or at the top where the fuel goes in ? thanx..Barry
Apr 21, 2008 at 4:34 PM
2CARPRO JACK
  • 11,533 POSTS
That is one of those things that you just have to try one way to see if ti gets you access, our software doesnt have any instructions for that procedure, there are some things that they expect us to just figure out.....lol
Apr 22, 2008 at 12:43 AM
CORVETTE96
[quote:a712c9fa30="corvette96"]Electrical problem
1996 Chevy Corvette V8 Two Wheel Drive Automatic 30000 miles
I want to install a new third brake LED light kit..How do I get to it to remove and change it out...At the license plate or at the top where the fuel goes in ? thanx..Barry[/quote:a712c9fa30]...answer: I found out by myself. You must take off the license plate, then you can reach up and remove the third brake light..there is a 9/32 screw on each side to remove, then it will come off...it's a job but not hard all at..I also took off the license plate light, too...hope this helps someone...
Apr 22, 2008 at 9:46 AM
