1996 Chevy Corvette The car runs fine then stalls
1996 CHEVROLET CORVETTE
100,000 MILES • V8 • 2WD • AUTOMATIC
DPMURPHY123
Ok so heres the problem i am having i start the car up it runs perfectly fine then after about ten minute maybe little longer or at a bout 190-200 degrees tempature the car stalls. then i have to wait a couple seconds at the least b4 it will start then it stalls again. the most ive had to wait is around an hour. I have recently changed the egr valve and sensor/module check the ignition module and also check the ignition coil. I was putting off a heavy gas smell but i realized all this was coming from leaky injectors witch i fixed. Keep in mind the car had all these problems before i started messing with things. thanx and i would greatly appreciate your help. thanx again
Mar 5, 2008 at 9:25 AM
BLACKOP555
  • 10,386 POSTS
try a new spark plugs and wires and see how that solves your problem, if not post back and we will continue.
Mar 5, 2008 at 12:58 PM
