1996 Chevy Corvette Driver side door window guide
71,256 MILES • V8 • 2WD • AUTOMATIC
DAVID E
Hello, My driver side door window guide broke off . the part that bolts thru the glass is still there and must be removed and of course replaced. It is a little tight in there , what is the best way to go about replaceing this part. I have the door panel off and can see where it goes . any advice will be appreciated
Oct 28, 2008 at 7:20 AM
IMPALASS
  • 3,112 POSTS
Hello Well, Sir, the biggest advice is plan on taking your time, going slow and be patient. I have taken apart many doors, worked windows etc. They have all been shall I say.....interesting. Normally it is easier with two, but get a rubber door stop wedge and wedge that between the glass and the door to keep it in whatever position works best. You will need a couple of different ones. I have found it easier to remove the glass totally from the door, replace hardware and reinstall. The use of ¼ drive ratchets work best to me due to the space. Also if you have ratchet wrenches per the pic they work really well too.
https://images.2carpros.com/forum/automotive_pictures/248015_00942173000_1.jpg
Don't let the window fall. The wedge will help but don't always trust. Sometimes I put a cut 2x4 in to keep it to a short fall if it does. Watch if you do decide to pull the glass all the way out which I like best, not to chip it and keep at the correct angle. It is amazing to me how strong the glass is but yet it only takes 1 little tic.... Edges are sharp.......I would show you the scar of the stitches but no need.....so move slow and precise. You may find you will be talking to yourself saying: "Now how in the world did they get all of that in there and hands?"......this is perfectly normal to include answering yourself with ----"I don't know.".
Oct 28, 2008 at 2:16 PM
