The drivers side window does not operate. It has a duel switch and the the one for the passenger side still operates that window.
Feb 26, 2010 at 6:35 AM
TOOOMANYTOYS
✓Experienced Mechanic
Remove the driver side door panel. Remove the connector going to window motor. Place a test light to the connector move the window switch if it light up in both positions it most likely needs a window motor. You can also try tapping the window motor and see if it tries to work.
Feb 26, 2010 at 6:40 AM
