1994 Chevy Corvette 94 vette dies
92,000 MILES • V8 • 2WD • AUTOMATIC
BDUKE
I have a 94 vette that goes dead at idle or going down the road off the gas. It is like u turned the car off while going down the road or at idle. It shows no signs of going dead before it does this. It usually does it around 1 or 2 miles from home. We have replaced distributor, idle speed motor, egr valve, and checked fuel pump pressure. It does not throw a code either. Do u think we need a new computer or any other suggestions!!!
Jul 9, 2008 at 5:48 AM
MMPRINCE4000
  • 8,548 POSTS
Did the new dist. come with an ignition module?
I would also check that all the grounds are good and tight.
Inspect wiring harness for any signs of excessive heat, like a leaking exhaust.
You can have the ECM scanned to see if it is operating properly, while it could be the ECM, generally if the check engne light comes on when ign. is on and goes out when started the ECM has run a self check.
Jul 10, 2008 at 2:11 AM
