if you have the normal distributor on top of the engine, you disconnect the esc wire it is a single wire by the air control valve on teh passenger side of the engine. do not disconnect the 4 way wire. loosen the bolt on the dist and connect the timing light to the #1 cylinder. set at 6 degrees BTDC. If you have teh distributor in the front under teh water pump there is no adjustment.
Jun 12, 2010 at 6:05 AM
