Would a blown head gasket sound like a blown header gaskets,i c the milky stuff on gas cap and stick,will Thermagasket fix this problem?
May 26, 2010 at 5:20 PM
BLUELIGHTNIN6
✓Experienced Mechanic
a cracked head gasket would not change the sound of the exhaust. it may cause the engine to idle slightly rough and cause overheating of motor though. i would not suggest using a repair-in-a-tube type product on a faulty head gasket. they usually make a bigger mess ..
May 26, 2010 at 5:25 PM
If its the headgasket that's blown you'll be overheating-Get it block and pressure tested.
