1990 Chevy Corvette starting
41,300 MILES • V8 • 2WD • AUTOMATIC
DENBURKE
the car starts hard the first time and smells of gas.
It idles rough and rpm fluctuate and sometimes it stalls when it's put into gear. I have done a lot of work on this problem and it still won't go away.
New injectors, new fuel pump, new wires, new plugs, new ignition module in the distrubutor. We don't know where to go next.
Sep 8, 2009 at 6:24 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs-Clean out the idle air control valve and test the TPS and MAP sensors
Sep 8, 2009 at 9:59 AM
