1990 Chevy Corvette fuel pressure relay
CRODRUMMER
Engine Mechanical problem
1990 Chevy Corvette V8 Two Wheel Drive 163000 miles
Is it possible that the reason my car bogs almost to the point of a stall when I press the accelerator is a bad fuel pressure relay or is it most likely the fuel pump? Also, how can I check these two components individually to check if they need replacing?
Feb 10, 2009 at 10:39 AM
  • 75,988 POSTS
What you need to do is check the fuel pressure to rule out the fuel pump and fuel filter
Feb 10, 2009 at 10:50 AM
