1989 Chevy Corvette WHITE SMOKE
1989 CHEVROLET CORVETTE
61,000 MILES • V8 • 2WD • AUTOMATIC
EZ4U46
when the car starts up and is driven it starts to run hot and then there is white smoke coming from both sides of the exhast. I checked the oil to see if there is any milky substance in it and the oil is clean. The over flow res. after I fill it will be empty when this happens.
Apr 18, 2009 at 6:44 PM
Get your cooling system block and pressure tested-white smoke points to coolant is being burn in the combustion chamber-couild mean blown headgasket, cracked head or block and intake gasket
Apr 18, 2009 at 6:54 PM
