1989 Chevy Corvette ENGINE SPUTTERS WHEN WARM
110,000 MILES • V8 • 2WD • MANUAL
SIMON001
Hi, Corvette L98 engine sputters and runs terribly under acceleration when it gets to operating temperature.
Sep 24, 2008 at 1:12 PM
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel filter/regulator and fuel pump. If it checks out-test the throttle position,MAF/MAP sensors and EGR valve.
Before you do above try running an injection cleaner and see what happens. Could also be a transmission problem
Sep 24, 2008 at 10:12 PM
