1989 Chevy Corvette A BAD CLUTCH
75,600 MILES • V8 • 2WD • MANUAL
MLUVERA
i was in need of replacing the clutch which i had an appt. I was driving the car this weekend and noticed the entine going yet the car did not accelerate. i parked the car and this morning when i put the clutch in and turned the ignition key the car would not start. is this related to the clutch failure or another unrelated problem
Sep 13, 2009 at 1:57 PM
  • 75,988 POSTS
Sounds like the clutch is slipping and for it not to crank -check the clutch switch, starter and ignition switch-Also check battery/connections
Sep 13, 2009 at 2:05 PM
MLUVERA
[quote:270d6afed1="rasmataz"]Sounds like the clutch is slipping and for it not to crank -check the clutch switch, starter and ignition switch-Also check battery/connections[/quote:270d6afed1]
the car engine turns over but the car does not start so if the starter were bad and or ignition, that would not do that am i correct?
Sep 14, 2009 at 1:35 PM
  • 75,988 POSTS
Cranks but will not start:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sep 14, 2009 at 4:11 PM
