1988 Chevy Corvette oiltemperature
123,000 MILES • V8 • 2WD • AUTOMATIC
FBAZAN
my 88 vette shows at times upto 226 degrees in the digital displat on the dashboard, while showing 185 to 206 on the water temperature reading.
what is the normal operating tempof the oil?
Sep 11, 2009 at 10:41 AM
PEAR69
  • 1,482 POSTS
The oil temp will be 30 to 70 degrees hotter that the coolant temp. depending if you have an oil cooler or not. If the question suggests what is a safe temperature for oil? Then what weight and type of oil are you using - synthetic or conventional?
Sep 11, 2009 at 9:34 PM
