1987, 2dr coupe, 112000 miles, tpi350. What is the proper oil running temp on this corvette to be, Thank you.
Tuesday, July 10th, 2007 AT 4:02 PM
STRAIGHT AHEAD
MEMBER
The car is fine. The car has a close systems. Just like cooling system when the temp gauge. Gets past the red zone. You need to be worried. Pull over and turn the car off. Good Luck
