1987 Chevy Corvette maf sensor
113,500 MILES • V8 • 2WD • MANUAL
FRANCES WEAVER
I have replaced the maf sensor with original equipment from GM, I keep getting a light that when checked shows the maf code, check engine light comes on car runs like crap, next time I start car the light might stay off for several mines but then pops back on and the engine bogs down, this is driving me crazy, no one seems to be able to find the problem, could you guys help a woman out here?
Jul 3, 2009 at 5:40 AM
LOUT5369
  • 217 POSTS
Check if there is a hole in the hose between MAF and the throttle body,If there is a hole in the hose you'll have to get another one,if there is a hole in the hose the engine will draw air from there and the Maf reading will be off,then the computer will try to compensate for the hole.Good Luck,lou
Jul 24, 2009 at 9:20 AM
