1987 Chevy Corvette FAN FOR HEATER
99,000 MILES • V8 • 2WD • AUTOMATIC
KINGOFSIAM
FAN COMES ON EVEN WHEN KEY IS OUT OF CAR. I WALKED UP TO THE CAR THE OTHER NIGHT AND THE HEATER FAN WAS BLOWING AIR INSIDE THE CAR. THERE WAS NO KEY IN EGNITION WHEN I STARTED THE CAR I PUSHED THE OFF SWITCH AND IT WENT OFF. A FEW MINUTES LATER THE FAN STARTED BLOWING AGAIN. WHEN I GOT HOME I TURNED OFF THE CAR AND THE FAN STARTED BLOWING AGAIN WHATS UP ?
Jul 22, 2010 at 8:15 PM
EDWARD.S
  • 166 POSTS
Hi, See If The Car Has A Heater Fan Control Module.If It Does ,That Part may be Bad .They Used Them On Cadillacs For a Few Years.And We Would replace them Often.The Blower Motor Would Be On Without The Key on .
Hope This Helps You,
Good Luck
Edward S.
Jul 22, 2010 at 10:25 PM
