1987 Chevy Corvette Engine knock
KMITCHELL473
Noises problem
1987 Chevy Corvette V8 Two Wheel Drive 75000 miles
I have a '87 corvette with 5.7 liter TPI motor and automatic trans. The car runs and drives great. The problem is when ever I accelerate hard I hear a knock in the engine. But normal driving and acceleration its fine I hear no knock. I thought the timing might be off so I looked and adjusted it back to factory spec (wasn't far off). the knock seemed like it got a little quieter but not really, I still hear the knock under heavy acceleration. i run 93 octane gas always. Not sure if it has adjustable rockers and there out of whack or what could be the problem.
Apr 20, 2010 at 5:31 PM
DOCFIXIT
  • 18,828 POSTS
Maybe detonation caused by carbon build up on piston top and cumbustion chamber. Also check to see if EGR is operating ie. vacuum to it at 2000rpms + lift up on EGR diaphram enginee should idle rough if passageways clear.
Apr 21, 2010 at 9:10 AM
