1986 Chevy Corvette Hood release
BIGREDCLOVE
  • 1986 CHEVROLET CORVETTE
Engine Mechanical problem
1986 Chevy Corvette V8
I am unable to release the passenger side hood release to raise the hood. The driver side releases and I am able to lift, but the other side won't budge. I have tried pounding, carefully with my hand, around the latch area to see if it was just sticking with no result. It seems the cables are not pulling to release the catch, but I have pulled the interior lever all the way.
any ideas?
Monday, August 17th, 2009 AT 2:09 PM
2CARPRO JACK
  • 11,533 POSTS
Get aflashlight and see if you can locate thecable that goes from d/s to p/s. It should be accessable if the d/s is unlatched. Try pulling it with pliers. If that wont work you may need to remove the p/s wheel and go in through th einner wheelwell panel, it unbolts with about 6-8 10mm bolts
Tuesday, August 18th, 2009 AT 7:51 AM
