1986 Chevy Corvette DASHBOARD
123,000 MILES • V8 • 2WD • MANUAL
GOLDIE86
Hi, Is it easy to take the dashboard off and when I put it back on should I use rubber washers .Thanks Randy
Dec 29, 2009 at 7:15 AM
ERNEST CLARK
  • 1,730 POSTS
It really depends on how much of the dashboard you want to take off. If it's just the dash pad (upper most piece), then that's relatively simple. If you want to remove the dash face, or center pieces, then that will be more of an involved process.
I recommend that you visit "corvetteamerica.com" or obtain a parts catalog from a company that specializes in corvettes. They'll certainly have new mounting hardware, and it'll allow you to research any other nick-nacks you may need.
Jan 7, 2010 at 1:11 AM
