1985 Chevy Corvette vacuum hose diagram
150,000 MILES • V8 • 2WD • AUTOMATIC
TOMGTAYLOR
Recently work was done to the intake manifold by a GM dealer. The vacuum hoses were not put back in their proper place. This has been rectified as the hose layout is shown on the radiator cowl. The problem is there exists a vacuum damper valve located near the EGR solenoid with 3 ports or hoses to be attached. One of these hoses goes to a vacuum cable assembly (cruise control??) above the battery, another to the last port on the air plenum reserved for the HVAC, the third??? I can not find any info on the proper hook up of this damper valve and its 3 hoses.[img:93261c3032]http://www.2carpros.com/forum/automotive_pictures/572322_IM002943_1.jpg[/img:93261c3032]
[img:93261c3032]http://www.2carpros.com/forum/automotive_pictures/572322_IM002942_1.jpg[/img:93261c3032]
Sep 13, 2010 at 1:25 AM
MERLIN2021
  • 17,250 POSTS
I will email what I have, but my advice to to complain at the shop that did the work, tell them the work is shoddy and needs to be done right. You did pay for it...
Sep 14, 2010 at 7:24 AM
