Recently work was done to the intake manifold by a GM dealer. The vacuum hoses were not put back in their proper place. This has been rectified as the hose layout is shown on the radiator cowl. The problem is there exists a vacuum damper valve located near the EGR solenoid with 3 ports or hoses to be attached. One of these hoses goes to a vacuum cable assembly (cruise control??) above the battery, another to the last port on the air plenum reserved for the HVAC, the third??? I can not find any info on the proper hook up of this damper valve and its 3 hoses.[img:93261c3032]http://www.2carpros.com/forum/automotive_pictures/572322_IM002943_1.jpg[/img:93261c3032]
[img:93261c3032]http://www.2carpros.com/forum/automotive_pictures/572322_IM002942_1.jpg[/img:93261c3032]
Sep 13, 2010 at 1:25 AM
