1985 Chevy Corvette SHORT IN DOORS
GILLES POTVIN
Electrical problem
1985 Chevy Corvette V8 Two Wheel Drive Automatic
I HAVE A TYPE OF SHORT THAT KILL MY BATTERY ,IN TWO DAYS IF I DO NOT REMOVED THE FUSE.THE FUSE THAT I HAVE TO REMOVED IS THE ONE THAT CONTROL THE RADIO AND THE LIGHT INSIDE THE CAR.WHAT COULD BE THE PROBLEM ? I DID NOT MAKE ANY TYPE OF REPAIR THAT WOULD CAUSE THAT. I HAD CHECK WITH MY MECHANIC IND HE TELL ME THAT I HAVE A ISSUE WHEN I OPEN THE DOORS. I HAVE ABOUT 4.5 AMP ON HIS METER.
Oct 27, 2010 at 12:32 PM
HMAC300
  • 48,601 POSTS
you need to check and see if any of your doorswitches have broken off at the back in the door post. you may have a wire that is grounding out anddrawing your battery down. theseoperate your courtesy lights insidethe car as well as an underhood light if you have one. I forgot it's been a while. Also if someone has hooked up a radio or security system they may have tapped into that wire and it may be causing it now.
Nov 1, 2010 at 10:48 AM
