1985 Chevy Corvette code 54 / low voltage in fuel pump circ
1985 CHEVROLET CORVETTE
167,000 MILES • V8 • 2WD • AUTOMATIC
JENCHEN2652
engine starves after reaching operating temp. replaced fuel pump, fuel pump relay, checked and cleaned everything i could see at least. something shuts the relay off at around 200 degrees....HELP
signed Frusteration...lol
mark
Jan 14, 2010 at 9:16 AM
RACEFAN966
  • 5,029 POSTS
Have you checked the oil pressure switch. This can turn off the fuel pump if it sees low pressure.
Jan 15, 2010 at 2:45 AM
JENCHEN2652
the gauge shows good pressure, and temp. so i hadn't thought of the switch. is that a good or bad only switch? i was thinking of injectors but hopeing for a simpler salution before that. ill check the switch first tho. thank you
Jan 15, 2010 at 8:09 AM
RACEFAN966
  • 5,029 POSTS
Ok check the red wire coming from the oil pressure switch this is the one that goes to the fuel pump relay to shut it off. Run the car up to temp and then check that wire for power once it dies. Let me know what you find.
Jan 16, 2010 at 12:42 AM
