1985 Chevy Corvette
DORNEY01
1985 Chevy Corvette
The right rear signal light is bad in my 1985 corvette and I cannot find an easy way to get to the bulb. It seems like I have to remove the entire back of the car and drop the fuel tank to get to the rear light bulbs. Is there a simple way to get to these lights? Thanks for an easy answer.
Oct 2, 2008 at 10:12 AM
PAULIES 85
They are a b**** to get to, take off your lic. plate and take out the little screws you see there, under your rear bumper take out the screw on the bottom of the bumper, you can now barely pull back on the bottom of the bumper, then lube your arms with crisco and reach up to the bulb socket twist it out and change the bulb, it's an 1157, good luck
Mar 5, 2009 at 5:00 PM
ARIE
You can also remove the rear wheel and the wheel shrowd. It's a little more work but saves having to use Crisco.
Mar 21, 2009 at 8:31 PM
