why does the manual transmission not engage when put in gear? Clutch is good, shifter is ok, no signs of slippage before, no leaks.
Jul 26, 2007 at 2:54 AM
MIKE H R
MEMBER
with the engine running can you shift it without using the clutch. With the engine off shift to first gear. press on clutch and then start the engine does the car take off or move?
