1984 Chevy Corvette no gas injection ECM?
87,000 MILES • V8 • 2WD • AUTOMATIC
EKSTRA4
the car turns over and starts if you poor gas in the carbs. the problem is the injectors not injecting in the carbs. the fuel pump pumps gas. I used a GM engine tester but got no codes,also used a papper clip to jump A and B, but no check engine lite. before I purchase an ECM, i would like cover the posibilities. the car ran before but as sat for several months, but it did fire
Dec 29, 2009 at 10:02 AM
  • 75,988 POSTS
Did you check the fuses for the injectors if okay check resistances of the injector solenoid
Dec 29, 2009 at 10:17 AM
