1984 Chevy Corvette Exterior lights
1984 CHEVROLET CORVETTE
THE57COWBOYS
Electrical problem
1984 Chevy Corvette V8 Automatic
All my exterior lights are off. The head lamps will not flip up. What should I look for or test?
Sep 27, 2010 at 2:18 PM
MIKE H R
  • CAR REPAIR CONTRIBUTOR
  • 3,094 POSTS
start with checking all the fuses. Also check the fusable links. Check the headlight relays. under the dash. Check the wires by the headlight motos with a test light. Check both sides of the wiring. When the headlights are turned on the voltage comes from one wire and when turned off the voltage comes from the other side to reverse the motor.
Oct 7, 2010 at 10:24 AM
