1984 Chevy Corvette
160,000 MILES • V8 • 2WD • AUTOMATIC
DRC502000
Changed ECM and coil and wires and plugs and fuel filter and fuel pump. Cleaned out gas tank and map sensor. Car still will not run correctly. Car will crank but backfires. The timing has already been checked. Someone suggested that the car may be limp home mode. If that's the case, how do I get it out of this mode? Any suggestions to what the next step should be?
Oct 12, 2008 at 6:25 AM
DOCFIXIT
  • 18,828 POSTS
How is engine compression?
Oct 23, 2008 at 5:14 AM
