1982 Chevy Corvette slight miss at idle
LMASSIE
Engine Mechanical problem
1982 Chevy Corvette V8 Two Wheel Drive Automatic uknown miles
This is a crossfire 5.7. Ive had the throttle bodys worked on because of an idle problem which was a prob lem for crossfire engines. I think it might be a plug, could that be possiable? It runs fine going down the road. Another possiable is a leaking vacum hose. The plugs on this car are very hard to get to unless you rack it. I have changed the dist cap and rotor. The plugs and plug wires were changed about 10,000 miles ago. Anything else I could check?
Sep 21, 2009 at 12:46 PM
ERNEST CLARK
  • 1,730 POSTS
The first thing to do is find out what cylinder is missing.
Hook up a tach. Then rev the motor to the r.p.m.s where it usually misses. Then remove one spark plug wire at a time (From the distributor cap).
Every time you remove a wire, the r.p.m.s should drop down. (about 500 r.p.m.) If you remove a wire and the r.p.m.s don't drop, then that cylinder wasn't firing.
Jan 8, 2010 at 6:15 AM
