1982 Chevy Corvette fuel injectors
90,000 MILES • V8 • 2WD • AUTOMATIC
BLESONDE956
I have an 82 crossfire corvette. Both injectors are spraying but as soon as I turn car on & rev up(floor it), the injectors seem 2 want more fuel(seems to be running out of fuel or not spraying thru injectors at high rpms...like its not getting enough thru the lines). I changed the fuel filter & the problem persist. Could it be a sensor or the fuel pump?
Jun 20, 2010 at 11:06 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs if okay test the injector solenoid resistance if okay get the computer checked out
Jun 20, 2010 at 12:13 PM
