1980 Chevy Corvette Squealing Brakes
FLEWWEI
Brakes problem
1980 Chevy Corvette V8 Two Wheel Drive Automatic
Had 4 new calipers and pads installed about a month ago. Now brakes are squeaking/sqeeling. Difficult ot determine which wheel(s) is making the noise. Happns mostly just as the car is coming to a complete stop. What/where do I look first?
Thanks
Jul 21, 2009 at 5:27 AM
LOUT5369
  • 217 POSTS
Do you have ceramic pads? Standard pads have metal in them,You could try disc brake quiet on the pads,First remove the pads,after you remove them apply the disc brake quiet to the metal backing of the pad,DO NOT GET IT ON THE PAD FACE. What is happening is the pads a vibrating when you come to a stop.Good Luck,Lou
Jul 24, 2009 at 9:34 AM
