1980 Chevy Corvette Diagnostic
1,300 MILES • 6 CYL • 2WD • AUTOMATIC
FRANK2010
i want to know where to find the DLC (diagnostic link connector) on my Corvette to check the engine through computer.
Where is it located at?
Jun 21, 2010 at 12:34 PM
HMAC300
  • 48,601 POSTS
it should be on the bottom of the dash by the steering column. cross terminal A&B and turn the key on and count the flashes. if you get a code 12 it means everything is ok. you can find the codes by coming back to the site here and looking under check engine light then OBD1
Jul 4, 2010 at 3:46 AM
