1979 Chevy Corvette V8 Two Wheel Drive Automatic alot miles
repairing old 79' 'vette' that has been around, but sat up about 10 years in need of repair.
Got it running and started on suspension. Then took motor down to repair valves. I.E. Head job. Runs fantastic now. Installed guages under hood -don't trust dash- needs alot. Cranked it up and lower radiator hose was squeezing flat. Took out the 195 degree thermo -left out and flushed. Added some flush stuff-no thermo and ran with radiator cap on. Drove but ran at 220. Cut off and cooled. Cranked up and upper hose was squeezing shut. What gives?New radiator buy the way. And I also wanted to flush cause I saw stuff floating in r. Fluid. Had to come from block.
SPONSORED LINKS
Friday, January 29th, 2010 AT 7:27 PM
