1979 Chevy Corvette oil
64,000 MILES • V8 • 2WD • AUTOMATIC
HARLEY912
driving down road about 55, puff of blue/white smoke out of the tail pipes, engine stops, it tried to re start put than locked up. found anti freeze in the oil the next day. I know thats not good but where did it come from? thks dd
Apr 4, 2010 at 11:54 PM
DR LOOT
  • 2,311 POSTS
most likely a blown head gasket, and if the engine seized up it may be a static lock because cylinders is full of water, remove your spark plugs and try to crank it over.
Apr 6, 2010 at 4:04 PM
