1979 Chevy Corvette distributor problems
73,000 MILES • V8 • 2WD • AUTOMATIC
SPLITWINCPE
i have a 79 corvette and it started runnig bad and popping through the carburator. i noticed the distributor had come loose and moves . now when you start it it idles real high then dies if you keep reving the engine it will run but not right could it be timing or bad distributor
Nov 18, 2009 at 3:28 AM
  • 75,988 POSTS
You need to redo the ignition timing
Nov 18, 2009 at 8:42 AM
