1976 Chevy Corvette Starting engine
12,000 MILES • V8 • 2WD • MANUAL
COOLERS
This car has been setting for over 10 years. What do I need to do to see if the car engine still starts and runs? The battery is dead and i don't think the gas tank was empted. Thanks Harris
Nov 1, 2009 at 4:46 AM
ERNEST CLARK
  • 1,730 POSTS
If the gas tank wasn't emptied, then there's definitely a bunch of gunk in there you don't want in your engine.
So the first thing to do is thoroughly clean the tank, fuel lines (Which are probably rusty and no good), and fuel pump. Get a new fuel filter and clean the carburetor.
Next, drain the cooant, oil and tranny fluid, refill with new filters. Finally, change everything that has something to do with the ignition system. Even though some of these components may appear to be good, you don't want to trust a 10-year old ignition system.
Jan 7, 2010 at 11:27 AM
