1976 Chevy Corvette misfire
68,000 MILES • V8 • 2WD • AUTOMATIC
WCOOL
I have a problem with my Corvette missing at about 55 mph, just wondering could it be a bad EGR Valve or plugs and plug wires, it only has around 9,000 mile on the plugs and wires
Thanks
Mar 19, 2009 at 5:44 AM
DOCFIXIT
  • 18,828 POSTS
EGR not likely but plugs, wires and coil all good possibilities. No miss under acceleration?
Mar 19, 2009 at 5:57 AM
WCOOL
It seems to misfire or surge from 55 to 70 mph
Mar 19, 2009 at 6:07 AM
DOCFIXIT
  • 18,828 POSTS
Do you have points dist? if so check dwell 30 deg. also make sure centrifugal advance weights are free and apply vacuum in advance see if it moves and holds
Mar 19, 2009 at 6:11 AM
WCOOL
I have a HEI distributor no points
Mar 19, 2009 at 6:24 AM
DOCFIXIT
  • 18,828 POSTS
Same check the weights under rotor and apply vac to advance
Mar 19, 2009 at 6:27 AM
BOGONE
  • 8 POSTS
Check the coil, plug wires, and rotor. The rotors on gm hei ignitions system are know to fail. It arcs thru the rotor into the distributor shaft. But i bet its the plug wires.
Charlie
[quote:c499f8c3af="wcool"]Engine Performance problem
1976 Chevy Corvette V8 Two Wheel Drive Automatic 68000 miles
Thanks[/quote:c499f8c3af]
Mar 19, 2009 at 6:37 AM
