I have a problem with my Corvette missing at about 55 mph, just wondering could it be a bad EGR Valve or plugs and plug wires, it only has around 9,000 mile on the plugs and wires
Thanks
Thursday, March 19th, 2009 AT 12:44 PM
DOCFIXIT
MECHANIC
EGR not likely but plugs, wires and coil all good possibilities. No miss under acceleration?
SPONSORED LINKS
Thursday, March 19th, 2009 AT 12:57 PM
WCOOL
MEMBER
It seems to misfire or surge from 55 to 70 mph
Thursday, March 19th, 2009 AT 1:07 PM
DOCFIXIT
MECHANIC
Do you have points dist? If so check dwell 30 deg. Also make sure centrifugal advance weights are free and apply vacuum in advance see if it moves and holds
Thursday, March 19th, 2009 AT 1:11 PM
WCOOL
MEMBER
I have a HEI distributor no points
Thursday, March 19th, 2009 AT 1:24 PM
DOCFIXIT
MECHANIC
Same check the weights under rotor and apply vac to advance
SPONSORED LINKS
Thursday, March 19th, 2009 AT 1:27 PM
BOGONE
MEMBER
Check the coil, plug wires, and rotor. The rotors on gm hei ignitions system are know to fail. It arcs thru the rotor into the distributor shaft. But I bet its the plug wires.
Charlie
