1976 Chevy Corvette distributor replacement
1976 CHEVROLET CORVETTE
VETTELOVER
Engine Mechanical problem
1976 Chevy Corvette Manual
My 76 Vette has an unknown engine. I need to replace the distributor. Since I can't match a replacement by Year, Make and Model, will any 8 cyl. distributor work? The only markings on the old one are... Delco Remy 2086k. Thanks so much! Natalie
May 2, 2009 at 12:36 PM
DOCFIXIT
  • 18,828 POSTS
Most likely a 350 and any small block Chevy Dist will work. Are you going to switch to HEI? Get like a 82 HEI with vacuum advance.
May 3, 2009 at 6:57 AM
