1976 Chevy Corvette All instrument lights went out
83,000 MILES • V8 • 2WD • MANUAL
JEFSVPHX
When I stepped on the dimmer switch all the instrument/dash lights went out on my corvette. The fuse is good now what do I do and how do I do it?
Jeff
Apr 7, 2009 at 6:23 PM
JDL
  • 16,098 POSTS
When the dash lites go out, do the tail-lamps go out also? They get voltage from the same fuse circuit. Does rotating the knob for the headlite switch cause any reaction to the dash lites?
You can check the wiring circuit from the headlite switch. The feed for I/P illumination is a dark green wire. You can also check the feed to the lite switch.
Apr 8, 2009 at 2:18 AM
JEFSVPHX
Tail lamps still work and all lights still work except the instrument lights. The rotating knob does not cause any reaction at all.
Now what could be the problem? What do I check next! Thanks, Jeff
Apr 8, 2009 at 3:26 PM
JDL
  • 16,098 POSTS
You need to get at the wiring circuit for the lite switch, check the feed circuit to the instrument cluster, dark green wire.
Apr 9, 2009 at 12:53 AM
