it takes 5 or 6 minutes for the transmission to go in gear?
48,000 MILES • V8 • 2WD • AUTOMATIC
JERRY4914
after car sits for a day or so it takes 5 or 6 minutes for the transmission to go in gear then everything is normal , have changed fluid & filter. any suggestions. Thanks Wayne
Dec 13, 2007 at 10:51 AM
TOBYU
  • 89 POSTS
Is is cold there? A weak front pump in the transmission will cause no movement until it warms up a few minutes. You might try some TransX..it works wonders.
Dec 13, 2007 at 6:32 PM
  • 55,628 POSTS
Yep, I have seen the front pump seal leak and allow air to get into the system which takes a few minutes to work it way out. Lucas transmission additive works good for this. Also,m check the fluid level and condition as well and service the transmission if the fluid is dark or burnt smelling here is a guide to help.
Please go over this guide and get back to us.
Sep 28, 2024 at 11:42 AM
