Engine Mechanical problem
1973 Chevy Corvette V8 Two Wheel Drive Manual 78K miles
HI,I'M HEARING AN EXHAUST LEAK ,IT ALMOST SOUNDS LIKE IT'S COMING FROM AND EXHAUST VALVE NOT SEATING PROPERLY,WILL A COMPRESSION TEST OF THAT CYLINDER TELL IF THE VALVE IS NOT SEAT CORRECTLY.IF SO ,IT WOULD MOST LIKELY MEAN THAT I WOULD NEED TO REPLACE THE LIFTERS..WOULD A VALVE MAKE THAT KIND OF NOISE NOT SEATING RIGHT?
THANKS FOR YOUR TIME JOHNNYO
Jul 24, 2008 at 2:39 PM
