1967 Chevy Corvette air in caliper
54,000 MILES • V8 • 2WD • MANUAL
SJSERVER
I have to bleed the front brakes often and always have air only in the same front caliper. Could the runout on that caliper cause the piston to move in and out enough to cause bubbles to form in that caliper
Apr 27, 2009 at 2:08 PM
2CARPRO JACK
  • 11,533 POSTS
More likely it is sucking the air in around the pistons, common on those older vettes.They bore and sleeve the calipers with steel sleeves instead of the cast iron to prevent the air being sucked in due to pitting in the bore
Apr 27, 2009 at 2:13 PM
