1965 Chevy Corvette TRANSMISSION WONT SHIFT
50 MILES • V8 • 2WD • AUTOMATIC
THYNX
I just had my 350 transmission rebuilt. I had a shift kit installed also. when it was completed it ran fine shifted fine on the freeway and off for about 50 miles then all of a sudden it just wont shift out of gear checked the fluid whart can it be
Dec 29, 2009 at 1:32 PM
DOCFIXIT
  • 18,828 POSTS
Check to see if vacuum line is hooked up to governor. Also if line hooked and vacuum present see if fluid present in tube off govner. If fluid replace governor.
Dec 30, 2009 at 5:14 AM
