1964 Chevy Corvette Wheel to drum fit
1949STEVE
Tires and Wheels problem
1964 Chevy Corvette V8 Two Wheel Drive Manual
I purchased aftermarket wheels. Everything fits fine, however the center hole in the wheels is +/- 1/4" larger than the center hub protruding from the face of the brake drum. I realize the stock wheel center hole did not fit machine tight to the hub, but they did fit a lot closer. I've been told this makes no difference, that the lug bolts are all that support the wheel anyway. Is this true?
Oct 12, 2008 at 1:55 AM
MERLIN2021
  • 17,250 POSTS
If the new wheels match up to the lugs, you will be fine!
Oct 12, 2008 at 2:31 AM
