1964 Chevy Corvette rear blinkers
WINGNUTS
Electrical problem
1964 Chevy Corvette V8 Two Wheel Drive Manual
the blinkers stay on after the switch is shut shut off.but all four rr taillights flash.the front ones do not.if the brake is activated the blinker on the dash stays on, and quits flashing until the brakes are not held.there has been a new groung put to the lights and this did not do anything.the signal switch in the steering colum was new this year.
Aug 17, 2009 at 5:00 AM
HMAC300
  • 48,601 POSTS
if you had a new turn signal switch put on then i'd go there . You probably have corssed a wire with the hazard lights. The switch that was put on might not be the correct one an dhas a different colored wire.
Oct 13, 2009 at 6:16 AM
